2004 S60 Fuel Pressure Problems...Help! - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 12-05-2011, 10:07 AM
Default 2004 S60 Fuel Pressure Problems...Help!
Hello,
I'm new to the Volvo S60. This one has about 95,000 miles on it.
The dealer has just replaced the Fuel Pressure Sensor under recall. The problem was surging and stalling. The new Sensor didn't solve the problem.
I connected my code scanner and the fuel pressure is jumping all over the map. It goes as low as 5lbs. when driving (car jerks) and as high as 78lbs. and also throws a fuel pressure sensor code.
The mystery is that after about 30 minutes of driving, the car settles down and runs fine. The fuel pressure stays at about 54-55 lbs. I've erased the code and it doesn't return until the next day when the engine is cold when the problem starts all over again.
Could this be a loose wire on the fuel pump, a bad fuel pump or a bad fuel pressure sensor?
Any help would be greatly appreciated...many thanks in advance.
The Tenor Man
Old 12-05-2011, 10:20 PM
how about a bad fuel pressure regulator? stay stuck open in the morning ( low press) or stuck closed ( high pressure) later?? I'm new to volvo's but i've had similar issues with other cars.....if these cars are like other ones i've worked on, the fuel pump always runs.....constant flow rate......the pressure regulator adjusts the pressure by allowing some fuel to flow back to the tank......worth thinking about!
Thread Thread Starter Forum Replies Last Post
2004 S60 Fuel Pressure Sensor replacement jmpaul88 Volvo S60 & V60 1 08-14-2014 09:39 PM
2004 Volvo S60 Fuel Pressure Huck Volvo S60 & V60 1 01-07-2014 09:46 AM
Fuel Pressure Regulator - Same thing as Fuel Pressure Sensor? MntnDewMan Volvo S60 & V60 1 11-19-2013 02:59 PM
2004 Volvo S40 fuel pressure regulator location hoffmandirt Volvo S40 3 01-24-2010 07:25 PM
Problems with fuel pressure (?) when low on fuel chaniewski Volvo S80 2 11-13-2007 06:50 PM
Tags
05, 2004, ford, fuel, high, pressure, problems, regulator, s60, s60fuel, sencer, sensor, symptoms, volvo, vovo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
