passenger side headlight doen't work
Old 11-01-2012, 02:46 PM
krazylu's Avatar
Default passenger side headlight doen't work
I bought new bulbs
checked all the fuses
the driver side bulb is the only ones that works.
my high beam works.
so any suggestion would help thank you.
Old 11-02-2012, 01:31 PM
01_fast_ride's Avatar
When you replaced the bulbs how did the wiring and plug look? Did you see any corrosion or heat damage? I would start by looking it over closely.
I had a turn signal socket go bad. The bulb still worked, but when I went to signal it went bonkers. No obvious damage to the socket. I replaced it and everything has been fine.
I hope that helps.
Markvolvo
12-29-2013 01:23 PM
BillLisa
06-27-2011 11:29 AM
ToledoVolvo01
04-30-2010 09:34 PM
paulfurtado91
01-24-2010 11:35 AM
chadman551
09-24-2009 01:01 PM
Quick Reply: passenger side headlight doen't work
