2006 s60 thermostat - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 10-28-2012, 09:00 PM
Default 2006 s60 2.5T thermostat
hello. i am in need of a new thermostat, or so I've been told. the temp needle seems to want to stay on the cold side. i know that i will need the full housing thermostat. my question is, how difficult is it to remove and replace? i can see the thermostat is held in by two screws, are there any more screws that holds the housing? i can not find a tutorial on R&R on the whole housing. if anyone has any info/input, it would greatly be appreciated. thanks!
Old 11-01-2012, 08:19 PM
looked at some tutorials and found some info useful. I've got the replacement part and it looks like only two screws. I've already got the top one loose but am having a hard time with the bottom one. would i need to remove the power steering pump to get the job done? is there any tips/tricks? i also bought an extension for the t40 torx as well.
Old 11-03-2012, 07:26 AM
well, finally got it done yesterday. took about 4 hours for me. it was pretty easy taking the thermo out but putting it back in was a pain and dropping the bolt in the engine bay somewhere was no fun either. but found it and put it all back in and everything works good now. the needle is up in the middle like usual on the temp gauge.
Thread Thread Starter Forum Replies Last Post
S60 T5 thermostat replacement Lex Hawkins Volvo S60 & V60 1 02-07-2011 05:53 PM
How to change thermostat and ECT on S60 jstarman General Volvo Chat 10 11-09-2010 06:32 PM
Time to replace Thermostat robert213 Volvo 850 15 05-30-2006 03:23 PM
Thermostat question Buck Volvo 240, 740 & 940 2 08-23-2005 09:20 AM
Coolant leak -- it was the thermostat jcmartin Volvo 850 1 03-01-2005 01:46 PM
Tags
07, 2006, 25, 25t, 40, cold, forums, replacement, s60, s6025t, thermostat, thoermst, voc, volvo, vovlo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
