Can the Camshaft be turned CCW on 2002 s60 if timing belt is off
Old 06-24-2012, 01:43 PM
DeanH's Avatar
Default Can the Camshaft be turned CCW on 2002 s60 if timing belt is off
Can I turn the cranksaft CCW 1 tooth to align it with the original mark with the timing belt off without doing any damage to the engine on my 2002 S60
Old 06-24-2012, 08:38 PM
Nichals's Avatar
yeah its normally 3 teeth when you start tapping valves
but why do you want to move it?
Old 06-25-2012, 08:20 PM
DeanH's Avatar
I need some help. I replaced the timing belt of my 2002 S60. I marked both camshafts and the crankshaft in their current positions, then removed the old belt. After replacing the belt, I had to turn the crankshaft to take up some of the slack and as a resut, after i turned the cranksahft two complete revolutions, and now if I line of the crankshaft marking, the camshaft positions are off 1 tooth(-1) and if I line up the camshaft marking, then the crankshaft is off 1 tooth (+1). I believe the issue was in taking up the slack, my question is how do I get these marks to now line up correctly as it would appear that no matter what i do, one of these is going to be off? Is there some procedure I can do to get these marks to line up correctly?
Old 06-26-2012, 12:43 AM
migbro's Avatar
I'm surprised you're asking this as you've already done the TB job. There's no procedure other than to remove and replace the timing belt correctly. If this were my car I'd put the crank on the timing mark then lock the cam pulleys with this tool. Loosen the tensioner then carefully jockey the belt off both cam pulleys and then replace it back on the cam pulleys one tooth advanced (or retarded, whatever).
steven_felton
04-01-2014 08:20 PM
jonqu
09-09-2013 12:31 PM
JHudson
06-21-2010 04:04 PM
Quick Reply: Can the Camshaft be turned CCW on 2002 s60 if timing belt is off
