Difficulty in finding fuse for lighter socket for S60 - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 05-14-2010, 05:41 AM
Default Difficulty in finding fuse for lighter socket for S60
SOS. I have problem in locating the fuse for the lighter in the S60. Even the mechanic can't locate. Please help. Tq.
Old 05-15-2010, 10:03 AM
Should be number 13 in the side of the dashboard.
http://new.volvocars.com/ownersdocs/..._11b.htm#pg186
Old 05-16-2010, 04:23 AM
Mad Matt's Avatar
Not in my '05 S60R. It was the #11 fuse in the fuse box under the dash in not so easy location. You'll need a tq bit to remove the cover though, if in fact it's there.
Each model year had a different fuse layout.
What year is your S60? If it's not the '01 like Anjow mentioned or the '05 like I have. Look here to find the correct online owners manual for your car.
The fuse your looking for is called the "12-volt sockets".
Old 05-16-2010, 08:58 AM
thanks anjow and matt. i check, my year is 2006.
Old 05-16-2010, 11:52 AM
Won't be the thing I posted then, since that's for 01-04 I think.
Old 05-16-2010, 02:19 PM
Mad Matt's Avatar
Yep, should be #11 under the dash...
http://apps.volvocars.us/ownersdocs/..._11b.htm#pg157
Like i said, you need a tq bit to get the cover off, and being flexible helps.... lol.
Old 06-23-2010, 02:08 PM
Did you have success replacing the fuse for your cigarette lighter socket?
I use the socket to recharge my cellphone on the road. A friend stuck a pen in the socket, and it sparked, a little bit of smoke, and then it won't charge anymore. So I need to check the fuse to see if it is blown.
Old 06-24-2010, 03:01 AM
Yes, I (or rather the mechanic)found the fuse. It is under the steering wheel. Thanks guys!
Old 06-24-2010, 08:45 AM
Congratulations that you have found it!
Old 04-11-2015, 06:03 PM
2006 S-60 fuse for lighter. Not 11 or 13. I have removed many fuses and can't get outlet to work but know it is the fuse argh!
Thread Thread Starter Forum Replies Last Post
Replacement Fuse for 2012 S60 T5 Cigarette Lighter Jilali Volvo S60 & V60 4 07-13-2015 01:26 PM
lighter socket - blown fuse? fiey24 Volvo S40 2 04-05-2014 07:10 PM
Make cigarette lighter socket hot in key off b26440510 Volvo 850 1 11-04-2011 10:02 PM
Lighter socket fuse shorts out njcardsfan Volvo V70 9 09-27-2010 07:54 AM
2000 S70 lighter socket issue Delirious Volvo S70 3 09-10-2010 03:57 PM
Tags
12, 2005, 2006, cover, fuse, lighter, outlet, power, removing, s40, s60, s80, socket, t5, volt, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
