Sponsored by:
Sponsored by: DashLynx
emission system service
Old 12-25-2004, 07:45 PM
tcarp104's Avatar
Default emission system service
the emission system service requirement light went on in my car along with the check engine light, before I go to my dealer can someone give me info as to what may be causing it. Can my mechanic do a routine check or should I go to volvo?
thanks for any help.
Old 12-26-2004, 01:06 AM
Default RE: emission system service
You probably have a bad throttle body or a bad o2 sensor.
Old 12-27-2004, 08:24 PM
tcarp104's Avatar
Thanks Tech, I took it to my mechanic & he ran a diagnostic on it, came up code P04020, which is catalytic below threshold. He said it's either the catalytic (which is still warrantied) or a bad O2 sensor. Volo said it would be abot 300 to replace the sensor. Does that sound reasonable?
Old 12-28-2004, 03:14 AM
Sounds pretty close but I would replace both sensors because when 1 goes bad the other usually does to.
Old 01-04-2005, 10:34 AM
Tech, looks like this is a common problem with the S60. So can this be done by a regular mechanic other than the volvo workshops?
Old 01-04-2005, 11:48 AM
Pretty much anyone that can work on a car can replace the O2 sensors.Its really not that hard.
robingichuhi
02-22-2017 04:34 PM
S80guy
08-18-2014 07:18 PM
mingster
08-20-2006 11:23 AM
volvo888
06-06-2006 09:12 PM
OverTheTop
05-06-2006 09:50 AM
Quick Reply: emission system service
