how do i check my transmission fluid
?? The 06 has the same yellow dip stick as my 03 i believe .If it does it will be drivers side below left side of the air box is the Trany it should be on the left side of that.If its there its really down there about arm length.Its a small yellow stick.
MYS6T is correct....the dipstick is yellow and located towards the right side of the engine down low.....my was hidden by a hose so really look hard and you will see the tranny stick it is half the length of the oil stick!!!
