Idle Surge
Idle Surge
My '02 S60 (non-turbo) has 83K miles. When in park it has anidle surge. No big deal, just annoying. I have been using "Lucas Upper Cylinder Lubricant" in my gas for the past two fill ups. I thought the surge may be due to dirty injectors. It has not gotten better. Any suggestions????
RE: Idle Surge
ORIGINAL: tech
Take it to your mechanic.
Unless you are up to the task yourself.
It is pretty easy to do. Remove the hose from the air box to the throttle body and clean the throttle body with a rag and some brake cleaner.
I would suggest getting Throttle body cleaner in an aerosol can that is safe for most applications.
