Metal on metal noise when i turn at slow speeds. - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 04-20-2017, 05:31 AM
\/sauce's Avatar
Default Metal on metal noise when i turn at slow speeds.
I have an 09 s60 2.5t. I had my struts and an alignment done about a month ago. Everything was perfect for a couple of weeks but now im hearing a horrible noise when making tight turns (in and out of parking spaces usually) i hear a sound like metal catching on metal. It is coming from my right front wheel. It always happens at the apex of the turn and then again when i straighten my wheel. It only happens if the car is rolling, never when its stopped. When the noise happens you can see the wheel jiggle. I feel like my wheel must be catching on something but i cant imagine what. Any input or advice would be appreciated. I have no idea where to start.
Old 04-20-2017, 06:38 AM
Probably just the backing plate. You can try pushing it back from the rotor with a long screwdriver through the spokes of the wheel.
Old 04-20-2017, 06:46 AM
\/sauce's Avatar
Thanks ill give that a try. I hope its that easy. Wouldnt that cause it to make a consistent noise tho? What im dealing with isnt consistent at all.
Old 04-20-2017, 08:49 AM
Not necessarily. In most cases I've seen, its on sharp turns only.
Old 04-20-2017, 09:26 AM
\/sauce's Avatar
I pushed it back as much as i dared to. it didn't seem to make a difference. there's about a half inch gap between the rotor and the backing plate. how large of a gap should there be? I can fit my finger between the two all the way around. the noise I'm hearing/feeling is more of a solid clunk than a scrape. it feels like it might be coming from deeper inside. any other ideas?
Old 04-20-2017, 10:17 AM
I have seen shops leave the rubber isolator out that sits between the spring and strut mounting plate for the spring. If the spring was binding or jumping because they reused the upper strut mount or the upper insulator then that could be where your sound is coming from. Look at part #36 in this diagram to see what the lower rubber insulator looks like:
http://www.volvopartswebstore.com/products/Volvo/S60/Insulator/8684669/31329206.html
#8 up to #4 should have also been replaced. Many non-volvo shops reuse these parts and send you back out the door only to encounter more squeaks thumps and bangs down the road.
Old 04-20-2017, 10:47 AM
I'd really have to hear it and inspect it to help. Possible ball joint, tie rod end, control arm bushing, etc.
Old 04-20-2017, 10:36 PM
\/sauce's Avatar
the struts that were put on were full coil over assemblies bought from IPD. I'll double check then tho. Thanks
Old 04-20-2017, 10:43 PM
\/sauce's Avatar
Quote:
i read that the control arm bushings are notorious for going bad. I haven't checked mine but im at 160,000 miles. I wouldnt be surprised if they were worn out. Theres a definite clunk accompanied ny a slip in traction in the middle of tight turns. You can see the top of the wheel "pop" outward a slight bit. Would the bushings cause that?
Old 04-21-2017, 06:20 AM
Yes, they can.
Thread Thread Starter Forum Replies Last Post
Metal on metal scraping noise rhys_d1983 Volvo S40 0 12-07-2011 11:09 AM
Metal to Metal sound in back of Engine checksix Volvo V70 7 07-17-2010 09:01 PM
metal on metal gordon368 Volvo S80 2 09-01-2009 04:15 PM
Metal on Metal squealing when taking off from a stop. Rascal2pt0 Volvo V70 0 12-01-2008 10:26 AM
metal scraping metal?? beach4me Volvo S40 5 04-06-2008 07:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
