P0016 ?? - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 02-13-2007, 09:17 PM
Default P0016 ??
My check engine light recently came on. Code scanned was originaly P0011.
Cam Position Sensor was changed and now receiving P0016. Does this mean the cam sensor
was installed incorrectly? Or has the timing belt jumped a tooth?
Old 02-17-2007, 02:13 AM
Default RE: P0016 ??
Has the timing belt been changed?
Old 02-17-2007, 11:04 AM
Timing belt is the original belt. The car has 56000 miles on it. I removed the vvt solenoid assembly and cleaned it to make sure it was not clogged. I'm planning on brining in and have a diagnostic done in a week. Is it also possible the thermostatic tensioner maybe at fault.
Old 02-17-2007, 12:26 PM
It could be many things.
You just removed the valve mounted to the top of the engine?
The timing might be off or that valve might be sticking.
Have the Cam seals been replaced?
Old 02-17-2007, 11:42 PM
Engine has never been apart. Car was running great and then one morning started it up and had a code for a bad cam sensor. Replaced the cam sensor and now have the code P0016. Seems kind of strange that this sequence of events has happened. I'll let you know what the dealer says.
Thanks for the inside.
Old 02-17-2007, 11:53 PM
A bad Crank sensor could do it as well.
Old 02-22-2007, 11:59 AM
I received the car back yesterday unfixed from the dealer. They game me a printout of the faults that were detected. A lot of intermittent stuff. So I guess I'm going to take a look at the timing marks myself this weekend and make sure the belt has not jumped a tooth. The printout was about five pages of every code every received. The one I'm having a problem with is 643A which according to the computer has occurred over 4000 times. So this has been an on going problem that was never resolved.
Old 02-22-2007, 10:01 PM
Quote:
ORIGINAL: bghubr
Which one is that I don't have the info on me right now?
Old 02-22-2007, 11:05 PM
The 643A is Camshaft position exhaust signal too high. I'm not sure what that means.
Old 02-22-2007, 11:21 PM
Yes check the timing.
You said it has a new sensor correct?
Old 03-04-2007, 09:27 PM
Just finished putting a timing belt in the car. The belt was off 2 teeth. Along with the belt I did the tensioner and idler. Car only has 54k on it. Now the code P0016 is gone. So for those who are receiving this you should think about having the timing belt looked at.
Old 03-04-2007, 09:50 PM
Glad you got it figured out.
Thread Thread Starter Forum Replies Last Post
Error Code P0016 greenestarr45 Volvo S80 0 01-25-2015 01:26 PM
P0016 after head replacement 2005 S40 rpilote General Volvo Chat 0 10-20-2012 03:22 PM
check engine light code P0014 and P0016 the_brain3000 Volvo S60 & V60 0 07-22-2010 02:34 PM
Changed timing belt now have code P0016 MNS60 Volvo S60 & V60 3 01-06-2010 10:10 PM
Tags
02, camshaft, check, code, engine, error, light, p0011, p0016, s40, s60, s80, timing, valve, variable, volvo, xc90
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
