rear hatch on S60 doesn't open with remote anymore...Can anyone help out there???
The other day when I went to open my rear hatch with my remote on my 2003 S60 2.4T, nothing happened. I had to use the car key to open it manually. All the other doors open with the remote, however, when I hit the rear latch button on the remote, it doesn't open, or even make any kind of noise. Any advice would be greatly appreciated. Thanks!
__________________
Rick Manning
__________________
Rick Manning
latch
I too am having the same problem. My 2002 S60 trunk button (above Lic. plate) never has worked. I bought this car used in 2006. I was fine using the key fob. That stopped working a few months back. Now I have to use the key. Worse part is my trunk lights staying on for extended periods of time.
My info panel on my dash says the trunk is open, when it's definately closed. I disassembled the trunk and got to the wiring to check and see if something came loose. If I manually push the latch in, the remote will open the latch. If I close the latch again, the trunk button on the trunk (magically) starts working.
Both of these will open the latch while I manually push it in with the trunk lid open. But, if I close the trunk normally, the info panel says it's open, and the key fob and trunk button will not work. I've looked at the latch loop(?) where the latch hooks too. It doesn't look out of adjustment, but who knows.
HELP!!!!!!
I'm hoping I just need to have the computer reset.
Anybody have any ideas, to help the OP and myself?
HELP!!!!!!
arifiano
06-07-2010 10:06 PM
doublegranch
07-29-2009 09:25 PM
