S60 2003 2.4T throwing P2407 code - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 12-07-2008, 08:52 AM
Default S60 2003 2.4T throwing P2407 code
I left for work yesterday morning and upon starting my 2003 S60 2.4T, the Check Engine Light came on. When I went to have the diagnostic code pulled at Pep Boys, they told me it was P2407 - Evaporative Emissions System Leak Detection Pump Sensor Circuit Intermittent / Erratic. Now that is a mouthful! Can anyone out there put this into simpler terms for me? Or has anyone else had this same problem? My car only has 63,000 miles on it. I've read some other postings where some people had mentioned the gas cap gasket. I've inspected that and it looks fine. Should I disconnect the battery and reconnect it to see if the Check Engine Light stays off, or might this problem be something else? Thanks!
Old 12-07-2008, 11:25 AM
Default RE: S60 2003 2.4T throwing P2407 code
Disconnecting and reconnecting the battery will not cause the light to come off.
I know, I have had the SRS Air Bag error for a month and lost battery power this week, the light is still on.
You'll have to have the problem taken care of.
Old 12-14-2008, 11:27 PM
if the gas cap was loose for a period of time it can cause an evap code...that will usually cause an evap emission small leak or large leak code to come on, i usualy work on domestic cars so i dont know if that would be the same as Evaporative Emissions System Leak Detection Pump Sensor Circuit Intermittent / Erratic...did they clear the code when you took it in? that is the only way the light will go off but if the problem is other than a gas cap the light will just come back on. you need someone to do ferther diagnostics on the evap system if the code was cleared and came back.
Old 12-15-2008, 01:25 AM
TIPSP's Avatar
Got Boost?
Info from VADIS
P2407 (ECM-431D) Leak diagnostic unit
Possible source
Signal missing:
-Contact resistance in the terminals
-Blocked hose between the leak diagnostic pump and the EVAP canister
-Defective leak diagnostic unit.
Thread Thread Starter Forum Replies Last Post
ECU keeps throwing knock sensor code, bad ECU ?? VolvoBug Volvo 850 6 10-13-2014 02:44 PM
new here, hid install, now throwing code.... hamsterhonda Volvo V70 2 04-16-2011 03:13 PM
Check engine light - code P2407 vincenzo Volvo S80 5 05-26-2010 07:39 AM
S80 sounds like a popcorn popper throwing error codes p0422, p0432, & p0300. Dano Volvo S80 8 01-06-2010 08:28 PM
HELP!! Tracs and ABS light on in dash and not throwing code?? DJ850R Volvo 850 6 04-30-2008 08:13 PM
Tags
2003, 24t, 431d, battery, code, codes, detection, diagnostic, leak, location, p2407, pump, s60, volvo, xc90
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
