S60 Power Seat Switches
Old 01-24-2011, 04:15 PM
jdsmith's Avatar
Default S60 Power Seat Switches
I have a 2006 S60 2.5. I need to remove the driver's side power seat switch assembly to inspect and clean the connections. How do I remove the panel and the assembly? I already have removed the seat.
Old 01-26-2011, 06:46 AM
jdsmith's Avatar
Default S60 Power Seat Switches Resolved
I removed the switch panel. The motor behind the panel has a wire connection on the top that had become loose. It looked like over time the wire was being pulled away from the motor (there was almost no slack in the wire to accomodate the movement of the seat). I cleaned the area and pushed the wire connection in tight. To help keep the wire in place, I wrapped two plastic wire straps tightly around the motor and wire. The seat now works!
admasters
01-01-2014 04:25 PM
bond007
01-24-2011 01:25 PM
Red October
09-16-2009 10:42 AM
Justos
01-18-2008 01:34 PM
blue goose
08-18-2007 12:30 PM
Quick Reply: S60 Power Seat Switches
