Check engine light on....car running cool
Old 03-28-2006, 02:06 AM
joe_boatwright's Avatar
Default Check engine light on....car running cool
I have a 01 S60 2.4T. The check engine came on and I noticed that the car is running cool, the temp gauge is only like 1/3 way up (1 notch below middle) at the warmest. I'm thinking its the thermostat.....how difficult are these to change? Is it right there under the 90' elbow into the block from the radiator?
Old 03-28-2006, 08:52 PM
Default RE: Check engine light on....car running cool
Yes it is on the engine where the Upper Rad. hose meets the engine. Remove the Torxes screws and replace the thermostat.
Also try to have the codes pulled to verify.
Old 03-28-2006, 09:22 PM
Where is the location for the OBDII Code reader???? I'm assuming its a little port somewhere, just cant find it. Thanks! - Joe
Old 03-28-2006, 09:37 PM
It is just above the hood release. You should see a panel that folds down.
geoworley
South
01-16-2014 03:53 PM
garysvolvo
08-14-2012 04:21 PM
scim06
03-26-2011 12:49 AM
850_96
07-20-2010 09:29 PM
mstrplmber
06-26-2010 04:10 PM
Quick Reply: Check engine light on....car running cool
