Spark plug replacement
Old 01-01-2008, 08:35 AM
Jay Bee's Avatar
Default Spark plug replacement
Hi all & Happy New Year: Could someone walk me through replacing the plugs in my, new to me 01 S60 2.4T. I have only replaced plugs in my Wrangler and the wifes Merc. Also the best plugs to use. Thanks JB
Old 01-01-2008, 09:47 AM
Default RE: Spark plug replacement
Either OEM pulgs or bosch platinums.
You have to remove the black top cover on the motor. (T-30 screws.)
Then you will need to remove the coil packs (10 MM)
The plugs are a 5/8 socket.
Old 01-01-2008, 09:53 AM
jks2's Avatar
After that it's righty-tighty, lefty-loosey. Make sure that you properly gap the plugs also.
Old 01-03-2008, 11:29 AM
Jay Bee's Avatar
There is an air intake pipe passing over the spark plug cover. Does this have to be removed? Any thing else that I should know? Thanks again JB
Old 01-03-2008, 08:05 PM
Remove the 2 t-25 screws that hold the pipe to the motor. Then you can lift it up some to slide the cover out from under it.
JSP
09-05-2013 01:36 PM
malaka
08-25-2011 12:15 PM
futbolfan15
04-02-2010 09:56 PM
VolvoS40S60
05-27-2009 02:43 PM
Quick Reply: Spark plug replacement
