98 S70 check engine light won't go off
I've been a mechanic for many years but I will admit I'm not as familiar with Volvos as most of you are so I'm seeking your input. A friend has a '98 S70, her check engine light was on, I scanned it and got two codes, P1307 Accelerometer and P0107 MAP sensor. I replaced both parts, cleared the codes. The CEL came back on within seconds of starting it. I scanned and it shows no codes. If I pull up data stream on my scan tool then recheck for codes the same two codes came back. I figured it meant the ECM is bad. Replaced it, same thing. If I clear the codes the CEL comes on but scanner pulls no coeds without going into data stream. The car runs well. I'm stumped on this one! What do I need to do to get the CEL to stay off? Thank you in advance for your help.
ErnstlS90
10-23-2008 08:37 AM
