98 S70 GLT alarm not sounding
Old 06-13-2008, 02:46 PM
S70GLT's Avatar
Default 98 S70 GLT alarm not sounding
When the alarm is triggered, the 4-ways flash, but no sound comes out. It used to work correctly until it went off one day and faded away as a scratchy noise for good within 10 seconds.
My horn still works though. So I'm confused as to why this has happened. Anyone know what could be the root of this issue?
Thanks all.
Old 06-13-2008, 08:39 PM
Default RE: 98 S70 GLT alarm not sounding
The alarm horn is different from the normal horn. The alarm one is mounted on the firewall by upper mount.
Old 06-14-2008, 12:53 AM
S70GLT's Avatar
Thanks, I'll check it out in the morning.
Old 06-15-2008, 12:04 PM
yu can trigger the alarm and look under the hood where tech said, it might still move but make no sound. Try tightening it up if its lose.
Old 06-15-2008, 02:22 PM
S70GLT's Avatar
Found it, and it was in fact loose, after tightening, it still did not work, I am going to try and modify the 850 alarm horn so that the plug works with the S70's.. will this work? they appear to be the same..
Old 06-15-2008, 03:54 PM
That should work fine.
Old 06-15-2008, 06:13 PM
S70GLT's Avatar
Thanks for your input tech
Vone
03-31-2014 11:05 PM
Cyburg
08-31-2009 06:09 PM
eyeballumbrella
02-09-2009 05:42 AM
crunch5868
Intake, Headers and Exhaust
01-11-2009 08:30 PM
805c70
08-30-2007 02:07 PM
Quick Reply: 98 S70 GLT alarm not sounding
