98 S70 hood-release cable broken, hood won't open. Any tips?
Old 05-25-2014, 11:39 PM
MDUBBSS70's Avatar
Default 98 S70 hood-release cable broken, hood won't open. Any tips?
So, After my hood-release cable snapped at the lever under the driver's side dash, I decided to try replacing the cable with a bicycle-gear cable by taping the new to the old and threading the new (carefully) through the existing tubing. However, I could not get the tape to stick and, after deciding to move the operation to a shop, closed the hood--that's when the existing cable came loose from the driver's side latch under the hood--closing the thing solid. I have done some snooping around and have found a few probable solutions, but thought I would throw the problem on here to see if anyone has been there. My next move is to remove the marker light and see if I can get to the latch with a hanger. Any tips are appreciated!!
Old 05-28-2014, 09:02 PM
240-FAN's Avatar
The marker light is your best bet. IF not break the headlight to get to it (replacement ones are like $80 on fleabay)
JeannieBeannie
03-06-2019 01:29 PM
aceniantor
02-06-2012 03:22 PM
87westy
04-12-2011 10:04 AM
skooter66
10-24-2009 09:42 AM
montysano
07-21-2007 09:24 AM
Quick Reply: 98 S70 hood-release cable broken, hood won't open. Any tips?
