99 s70 transmission, wiring harness, still will not run right.
about a month ago my transmission went out on my 1999 s70 with 223K miles. I found a used one and had it put in. i go to leave and the check engine light is on and it runs rough. i go back they check it and it comes back with
P0350 - Ignition Coil Primary/Secondary Circuit and
P0354 - Ignition Coil D Primary/Secondary Circuit.
so it was determined that i should get a new coil pack for cylinder D. i go and switch it out and the light does not go out. i go to check it and it comes back with
P0351 - Ignition Coil A Primary/Secondary Circuit
P0352 - Ignition Coil B Primary/Secondary Circuit
P0353 - Ignition Coil C Primary/Secondary Circuit
P0355 - Ignition Coil E Primary/Secondary Circuit
I bring it back to the guys that put it in and they have it tested at a friends shop with better equipment. they come back and say its a flywheel that is out of alignment. so they put one in and it does the same thing. I then take it to the dealership to get it diagnosed. they say it is a wiring harness. so I go get a used one because a new one is $1300+ so i find a used one and put it in. I start it up and it runs a little better but not good. i take it for a test drive and it dies after 1.5 miles. the codes that come back are the same as before and also P01081. i get it back home change out the plugs. its hard starts and runs rough.I clear the codes and they all come back but the P1081. I have been told that is it very very rare to have that many coil packs go bad at the same time.
Any help or suggestions would be greatly appreciated.
GrantRobertson
06-22-2013 02:42 PM
