Bypassing Heater Coil - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 05-22-2009, 06:20 AM
Default Bypassing Heater Coil
Hi - I have a 1999 S70, and recently noticed a strong coolant smell when running the heater/air. I brought my car into a mechanic, and they think the heater coil is leaking. They could not tell 100% since they would have to get to the coil to see if it was leaking, but no other leaks seem to be happening in/around the engine. My question is can I simply reroute the heater coil hoses from the engine to the heater coil so they bypass the heater coil, and could I be hurting the engine by doing this? It seems relatively easy to connect a hose from the engine where the heater hose lines start (supply) and connect back to the engine where the heater hose ends (return). I would lose use of the heater, but I never use it anyway. Thanks for answering.
Old 05-22-2009, 10:17 PM
You can unplug both hoses from the firewall and put a hose between them and it will be fine and not hurt the engine.
Old 05-23-2009, 07:31 AM
Default Thanks, and follow up question
Thanks for the reply - At least I will be able to reroute while I work on replacing the heater coil. Is replacing a heater coil a Do It Yourself project? I heard that the entire dash has to be removed in order to replace the heater coil. Thanks.
Old 05-23-2009, 09:55 AM
Yes it is a DIY job.
I the C70 section there is a post about replacing it.
The dash does not need to be removed to replace the heater core.
Old 05-23-2009, 11:19 AM
elcs70's Avatar
however, isnt it true that you have to remove the dash to replace the air conditioning condenser?
Old 05-23-2009, 11:52 AM
Yes that is true though.
Thread Thread Starter Forum Replies Last Post
Wiring to the Coil not firing the spark plug, Coil and spark plugs are new and GOOD? Kim Gregory Volvo S90 & V90 1 02-20-2013 09:02 AM
P0351 Ignition Coil A - P0352 Ignition Coil B Ricardito General Volvo Chat 0 08-14-2012 09:29 PM
Bypassing fuel pump relay chibeee Volvo 850 19 06-01-2012 03:37 PM
Bypassing the EGR james_caza Volvo 850 3 02-26-2010 11:29 PM
Bypassing my stock amp IdONtKNOw1230 Audio/Visual Electronics 5 12-03-2009 10:05 PM
Tags
1999, air, bypassing, changing, coil, conditioning, core, heat, heater, leak, pictures, reroute, s70, v70, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
