Creaking sound when turning both directions
Old 03-26-2007, 10:17 PM
Volvaman's Avatar
Default Creaking sound when turning both directions
Hi all,
I was wondering if anyone knows why my 99 S70 is creaking when nearly turning fully tothe left or right. Is this a CV Joint problem, ball joint, control arm problem or hopefully like bay 13 says the steering stops need to be greased? Any help would be grateful.
Thanks
Old 03-27-2007, 10:01 PM
reg's Avatar
reg
reg is offline
Default RE: Creaking sound when turning both directions
Could be your spring seats. Try spraying some wd40 on the bottom of the front springs. If things quiet down then you have found your problem. Then use some lithium grease and smear it in there.
r.
Old 03-28-2007, 09:46 AM
Volvaman's Avatar
Thanks I will give it a shot.
Old 04-01-2007, 07:32 PM
My '98 volvo s70 glt does the same thing, but I am new here and dont understand where the bottom of the front grips are?
Old 04-02-2007, 08:19 PM
reg's Avatar
reg
reg is offline
Look in the front wheel well. You will see the coil spring. Spray lube at the bottom of the spring....the spring seat.
flatlander
08-26-2015 06:13 PM
bkmuller
01-20-2012 02:26 PM
boldtu
09-03-2010 01:56 AM
eyukins
12-21-2007 08:10 AM
Quick Reply: Creaking sound when turning both directions
