Crummy Headlight Fix
Old 04-17-2016, 09:18 PM
firebirdparts's Avatar
Default Crummy Headlight Fix
I have had a couple of S70 and V70's where the headlights were very dim, and the problem was the reflector. I did a little research on this yesterday and I decided to try to fix them using Monokote Trim Chrome from the hobby shop. For $3, it's the cheapest fix, and being peel-n-stick, it's probably the easiest, and being about as reflective as a mirror, it has a good chance of being the best as well.
I just did one headlight so I could compare (so far). I was shocked. I think I have about 10X the light. I will have to post some pictures.
This stuff is sticky back mylar, so it'll be interesting to see if it peels off or crumbles to dust and when.
Old 04-17-2016, 09:30 PM
I'd be curious how it holds up to the heat. Should I be on the lookout for a Volvo in Tennessee with flames coming out of one of the headlights? :-)
Old 04-17-2016, 09:32 PM
Could happen...
Old 04-21-2016, 08:23 AM
This picture does not really do it justice. I think I have about 10 times more light on the "good" one.
Old 04-30-2016, 09:20 PM
I was thinking about doing the other headlight with aluminum duct tape, but I found the roll I had was not the shiny kind. So I have done the rest of the headlights with the Monokote mylar. I guess I'll report back in a year or when it peels off. $3 worth is enough to do all 4 headlights.
Old 05-01-2016, 10:44 AM
Psaboic's Avatar
Wow......Definitely see the difference. Please let us know how it holds up!!
Old 05-01-2016, 03:18 PM
I would post a picture of my sticker work, but it looks like a first grader did it.
Old 05-06-2016, 09:53 PM
97-850Wagen's Avatar
Ok, now I'm curious if this would work on my 850T lighting(s)... :think: it/they are terrible, particularly the low beams...Even with Hella Hi performance Xenon bulbs installed...bulbs made a difference over what was in there originally, but still terrible (although the 100w Hellas I put in the highs definitely made a difference lol )
Old 04-23-2018, 10:49 AM
Well, here's an update. I meant to check in after 1 years, but now it's been 2. This is working great. I can still clearly see the cut line, and both bulbs have a little bright spot of focus which approximately intersects on the surface of the road on dim. I don't see any deterioration at all. I will pull the lenses off and inspect and let you all know how it looks.
Old 09-28-2020, 12:54 PM
Well, here's another update. I went to the pull-a-part junkyard (just for fun) and there I found an S70 with brand new Taiwanese headlights. I bought them. so I am removing my repaired headlights. It's a struggle to photograph mirrors and lights, but here are some photos, such as they are. I decided at long last to show the appearance of my homemade "mirror" inside the lamp. The garage door below, it should be obvious, is repaired light on the left and Taiwanese on the right. The photo above was unrepaired on the left. The camera adjusts to overall light based on where you point it, and so I had all sorts of images. This image below is the one which made them look the most different.
Old 09-28-2020, 06:12 PM
patcal's Avatar
Is this the stuff you used?
Amazon Amazon
Holedigger
03-19-2012 12:19 PM
silkhope
03-20-2011 07:44 PM
Ruskya Mafia
06-21-2010 02:57 AM
4sfire
11-21-2009 06:57 PM
seagreens70
09-03-2007 04:03 PM
Quick Reply: Crummy Headlight Fix
