Dash board removal for mounting tab repair
Old 10-30-2013, 05:26 AM
redikqliss's Avatar
Ahh, good point. Now a cowrkr also ran by me that i could possibly try gorilla glue, again with that i wud have to keep pressure on the dash till it dries.
  #102
Old 10-30-2013, 05:28 AM
redikqliss's Avatar
Another idea was to perhaps brace the dash? And being im only loose on the driver side id only really hav to focus on securing that end. Any thoughts? I really appr. the feedback =D
  #103
Old 12-13-2013, 08:44 PM
cdnbluez's Avatar
I had 2 broken tabs. Removed the screws under the wiper plastic cover. Got a can of spray foam insulation. Inserted the tube into the screw hole and shot some foam in. The foam expands and hardens, no more squeaks.
  #104
Old 12-13-2013, 08:45 PM
I actually thought about doing that but chickened out. LOL
  #105
Old 12-13-2013, 08:53 PM
  #106
Old 10-10-2017, 09:43 AM
800artfreed's Avatar
Default Testing Repair for Lower Dash
Recently after damaging my dashboard I found a replacement at a parts recycle yard. Two of the tabs were broken off and a third was cracked. All the pieces were large and not missing. I used "plastic welding" to reattach the parts to the dash. Please search on the web for plastic welding. On youtube I found this video instructive,
There are other videos as well.
I purchased a 30 watt soldering iron from Harbor Freight. I cut off the shaft of a cheap small screw driver to create a flat welding tip for the iron. I also used black as well as "clear" tie wraps for sources of filler material.
The repairs look ugly but it is much less work than using epoxy (my previous repair). I have to swap out the bastardized harness on this dash with one from my left over dash. I will let you know how long the repair holds up. Flexing the repair by hand the repair seems strong. Remember this is a compression stressed attachment on the car.
The screw holder was somewhat tedious as you must slowly build up the material. I will drill a pilot hole for the screw so as not to crack the repair.
Good Luck.
1998 S70-T5 201,000 miles
Attached Thumbnails  Dash board removal for mounting tab repair-right-hand-tab-broken-base.jpg    Dash board removal for mounting tab repair-rebuilt-screw-holder-driver-kick-panel.jpg
Ahmed
11-07-2014 05:14 PM
rcvolvo
03-26-2013 12:52 PM
heavyphantom
11-16-2008 08:54 AM
deathbots
07-22-2007 10:06 PM
Quick Reply: Dash board removal for mounting tab repair
