Front suspension - harsh ride
Old 04-05-2006, 02:31 PM
branse's Avatar
Default Front suspension - harsh ride
Hello,
My 1998 S70 T5 has always had a fairly harsh ride since I bought it. Recently I replaced all four shocks/struts, without any change. I recently noticed that the middle part of the front right shock mount moves up and down quite a bit when I open the hood and rock the car, and the left doesn't move that much. Now, I didn't replace the shock mounts. Also, there is a creaking noise from the right shock mount, which went away after I sprayed some lubricant on it.
Any thoughts guys? I'm a little tired of being jolted around, I kind of didn't expect this from a Volvo. Is the suspension on the T5Se harder than that of a N/A S70? I'm running Michelin pilot tires, inflated to 28 psi. (205x50x16)
Thanks
Branse
Old 04-05-2006, 04:32 PM
S70driver's Avatar
Default RE: Front suspension - harsh ride
1. Sounds like you need to replace the mounts.
2. What did you replace the shocks/struts with? OEM?
3. Creaking noise could be the mounts, could be the spring seats I would assume as well.
Old 04-05-2006, 04:43 PM
branse's Avatar
That will prolly be my next step. But, do the mounts affect the harshness of the ride, and the jolting? I can even live with spraying some lube every couple of weeks, but the hard ride is killing me. (I have 2 little kids)
Old 04-08-2006, 02:50 PM
Yes it will make it ride harder.
But the S70 also doesn't ride like a caddy either.
Old 09-25-2006, 11:06 PM
branse's Avatar
Oh Gawd!!!
Since the last post many moons ago, I have replaced the strut mounts and changed to Goodyear assurance triple tread 205*55*16. I replaced the strut/rear shocks with OEM, and yet the ride is like a truck.
I really need to change something (springs???? Go with s70 non - turbo springs??)
My wife actually prefers to drive her minivan than the Volvo for comfort's sake.
Any help guys?
Old 09-25-2006, 11:10 PM
I think the turbo and Non-turbo springs are the same.
Not sure what else to tell you.
jorjelgt
02-13-2021 10:48 AM
Cruznlegend
1998-2000 model year V70
06-20-2014 12:41 PM
TonyS
06-13-2011 04:15 PM
zmontgomery
02-13-2011 12:24 AM
erndawg
06-05-2007 04:31 PM
Quick Reply: Front suspension - harsh ride
