Quick Vaccum Line Question
Old 01-02-2012, 05:28 PM
tomcfitz's Avatar
Default Quick Vaccum Line Question
So I have a 1998 S70 non-turbo, and I found a loose vaccum line, and I have no idea where its other end needs to go.
It was the line connected to the upper connection on the air filter, and it is about 10 inches long. I just bought the car, and so have no idea where the other end needs to connect. Could some good Samaritan check it out on their own car, and get back to me?
Old 01-03-2012, 09:12 AM
Congrats on your S70 purchase. Pictures will help us know what hose you are referring to. There is a vacuum diagram under the hood. Hope that helps.
Old 01-03-2012, 04:30 PM
tomcfitz's Avatar
Here are two pictures I took. I circled the place where one end connects.
The other end is the one I am confused about. The vacuum diagram was of no help to me, as I am fairly new to car repair, and have no idea what the things are called. Sorry. It would really be the most helpful if someone would just pop their hood, find the line, and photograph whatever it connects to.
A link to the pictures
Photo Album - Imgur
Old 01-03-2012, 05:58 PM
tomcfitz's Avatar
I think I got it figured out. That line was supposed to go to the valve that controls hot or cold air going into the intake.
I simply removed the metal pipe connecting the airbox to the exhaust system, and plugged the hole in the airbox. Now I should be getting only cold air into my engine, and hopefully life will be good.
Anyone see any problems with this? The coldest I will be starting this car in will be the single digits.
leung23c
12-10-2010 07:28 AM
denver005
10-18-2009 01:17 PM
crunch5868
03-22-2008 07:45 AM
S70driver
08-30-2007 11:08 AM
dcox612
04-23-2006 01:47 PM
Quick Reply: Quick Vaccum Line Question
