Help identifying oil leak
Old 08-31-2015, 06:25 AM
Heffo's Avatar
Default Help identifying oil leak
Does anyone know what the bolt highlighted in the photo is? Seems to be leaking oil. It's located under the water pump and appears to screw into the engine block. What do I need to do to reseal the bolt?
Old 09-02-2015, 12:38 AM
damien360's Avatar
I know it sounds like a stupid question bit are you sure the oil leak isn't coming from the exhaust cam seal? It looks like there's a bit of oil under the cam gear
Old 09-02-2015, 01:52 AM
Heffo's Avatar
Photo is not my engine. Only used to identify bolt in question. The bolt is the piston oil cooler jet control valve. It has a copper seal washer to seal it. The bolt was loose. Tightened and no more leak. Had to cut away a small portion of the rear plastic backing plate to gain access, but not too big an issue. If you have a leak running down beside the turbo oil feeder banjo bolt on the engine block, then keep this in mind. Thanks Guys
ZackieDarko
02-01-2007 08:36 PM
Black Belt Turbo
13
12-06-2006 01:46 AM
VolStang
01-07-2006 09:32 AM
jcmartin
08-12-2005 11:20 PM
Quick Reply: Help identifying oil leak
