Help identifying oil leak
Photo is not my engine. Only used to identify bolt in question. The bolt is the piston oil cooler jet control valve. It has a copper seal washer to seal it. The bolt was loose. Tightened and no more leak. Had to cut away a small portion of the rear plastic backing plate to gain access, but not too big an issue. If you have a leak running down beside the turbo oil feeder banjo bolt on the engine block, then keep this in mind. Thanks Guys
Black Belt Turbo
13
12-06-2006 01:46 AM
SirJeffrey
07-05-2006 09:06 PM
