Motorswap question
Old 04-23-2017, 10:28 PM
Seans70's Avatar
Default Motorswap question
So I have a 1999 s70 and the motor is done. However the ring gear is also gone I was just wondering if I swapped the motor like I was planning to would that fix the ring gear or would I still have to replace it?
May sound stupid but I'm learning here so
Old 04-24-2017, 07:45 AM
Psaboic's Avatar
When you have the motor out you will have to still replace the ring gear on the torque converter (automatic transmission) or the flywheel (Manual transmission) unless they just happen to be included with the new motor, but that is highly doubtful. If you have a manual transmission, I would do a clutch job at the same time while you have it all apart.
96850urbo
01-23-2009 01:00 PM
Adrenalin540
12-31-2008 10:19 AM
Aaronius
05-30-2008 06:10 PM
pvolvoman
10-24-2007 07:29 PM
mordezmoncou
04-09-2007 05:22 AM
Quick Reply: Motorswap question
