prop shaft bearing (U-joint)
Hello everybody
I just have my prop shaft removed. The U-joint bearing is shut. mechanic told me this part is not servicable and I have to put a new shaft ($1400 CAN, part only).
Does anybody know if I can replace the U-joint bearing?
(Right now the car is FWD)
RE: prop shaft bearing (U-joint)
Hello mate,
I did a bit of research but could not find a u-joint on AWD. I would try calling the following vendors:
http://www.fcpgroton.com/volvo.htm#c70
http://www.eeuroparts.com/productdet...&code=9157
The repair kit is at $229. You may be able to find a rebuilt prop shaft? Or get an entire prop shaft at a junkyard?
Sorry I couldn't be of better help.
JPN
JPN
