s70 hood won't opend ????
RE: s70 hood won't opend ????
Some times they are picky.Have you tryed having someone pull up on the hood while holding the release back?The hood release is a weird set up one cale releases 2 latches.Sometimes the cable stretches some and it is a pain to open the hood.I always keep a wooden wedge in my tool box for just such an occasion.You might have to play with the cable adjustment.First try libbing the heck out of the latches.Another thing you can try is using a pair of pliers carefully pull a little more on the cable inside the car once the handle is pulled all the way.
This is a shot in the dark, but my hood is doing the exact same thing. I took a small washer, cut a small groove in it. Then I pulled the cable ball away from the lever and slipped the washer between. I then took a pair of pliers and squeezed the washer shut. This is a cheesey way to make it work but it makes the cable a little longer. Sometimes it takes two little ones or one big washer. I am the redneck volvo repairman.
I have this problem on my V70. What works for me is that when only one side unlatches, I push down real hard on the hood and then go pull the inside realease again. It usually works after doing this. If not I have somebody lift up a little on the hood while I pull the release inside.
That fixed it. wonderful! thx
JeannieBeannie
03-06-2019 01:29 PM
MDUBBSS70
05-28-2014 09:02 PM
Red Tractors
08-20-2013 10:33 PM
