s70 turbo upgrade......
Old 03-16-2008, 11:06 PM
samadkins29's Avatar
Default s70 turbo upgrade......
Hey all, So I have a 98 s70 glt, what I want to know is will a 98-2000 t-5 turbo be a direct replacement to mine? I have an mbc to controll the boost, I just need to know if it will fit?
Old 03-17-2008, 07:08 AM
S70driver's Avatar
Default RE: s70 turbo upgrade......
It seems you have a 13g with a straight flange. Now looking at the chart it seems that the 1998 T5's have a 16t straight flange. Also if you can find it the,
[align=center]1996[/align] [align=center]850 R[/align] [align=center]2.3L[/align] [align=center]MT Euro spec[/align] [align=center]16T[/align] [align=center]Straight[/align]
So if this is correct then it is a direct bolt on.
If by some chance the chart is wrong and you have a 13g with an angled flange then you will need to look for a turbo from a...
1.
[align=center]1999[/align] [align=center]C70 coupe[/align] [align=center]2.3L[/align] [align=center]HPT[/align] [align=center]16T[/align] [align=center]Angled[/align]
2.
[align=center]1998[/align] [align=center]C70 coupe[/align] [align=center]2.3L[/align] [align=center]HPT[/align] [align=center]16T[/align] [align=center]Angled[/align]
3.
[align=center]1999[/align] [align=center]S70 T5, V70 T5[/align] [align=center]2.3L[/align] [align=center]All models[/align] [align=center]16T[/align] [align=center]Angled[/align]
4.
[align=center]2000[/align] [align=center]C70 convertible[/align] [align=center]2.3L[/align] [align=center]HPT[/align] [align=center]16T[/align] [align=center]Angled[/align]
5.
[align=center]2000[/align] [align=center]C70 coupe[/align] [align=center]2.3L[/align] [align=center]HPT[/align] [align=center]16T[/align] [align=center]Angled[/align]
6.
[align=center]2000[/align] [align=center]S70 T5, V70 T5[/align] [align=center]2.3L[/align] [align=center]All models[/align] [align=center]16T[/align] [align=center]Angled[/align]
Old 03-17-2008, 06:04 PM
I have located a 98 t5 for parting. Do you think the ecu would help at all? or is that going to cause problems?
Old 03-17-2008, 07:04 PM
S70driver's Avatar
ORIGINAL: samadkins29
personally I wouldn't use that ECU. Just get an ECU upgrade you will be much more pleased.
I know people have tried like 850T5R and 850R ECU's in a GLT 850.
Old 03-17-2008, 07:28 PM
most likly will, but thinking about it. The t-5 ecu would be programmed for a larger turbo. I know in a thread awhile back we had discussed the possibly of doing that instead of an ecu upgrade. But the key thing was that that ecu would be programeed for a larger turbo. So if its a t-5 turbo in my glt should teh t-5 ecu run good? That and both cars are teh same year, so their should be minimal differnce. Either way I would like to get and ecu chip in the end, but I can get the ecu for pretty much nothing if I buy the turbo.
Old 03-17-2008, 08:01 PM
S70driver's Avatar
Wont be worth it, trust me.
Just save your money for an ECU upgrade.
Old 03-17-2008, 08:07 PM
alright fair enough....
one other question I had was, where did you get the turbo info specs?
Old 03-17-2008, 08:11 PM
S70driver's Avatar
QuickBrickMotorsports (QBM)
1. http://www.quickbrickmotorsports.com/
PRODUCTS
2. http://www.quickbrickmotorsports.com/products.html
DOWNPIPE FLANGES
3. http://www.quickbrickmotorsports.com/prod_dpflange.html
APPLICATION CHART
4. http://www.quickbrickmotorsports.com...lange_list.htm
To easily get there click on number four. I just laid it out like that so if for some reason it didn't work you can get to it other ways. Each number is a step. and the words above each link is what you need to look for.
Old 03-17-2008, 08:31 PM
thanks!
Old 03-18-2008, 03:32 PM
How much differnce would their be between a 15g and a 16t? Both are avail, the 15g is alittle esier to get. How much mroe psi could I run on either of those?
thanks again
Old 03-18-2008, 07:03 PM
S70driver's Avatar
thanks again
Basically the same turbo. Personally I would go for the 16T though.
Turbo Flow Rates
15g 428cfm
16t 435cfm
Old 10-20-2010, 07:21 AM
CRC1021's Avatar
I have a 98GLT and swapped up to a 2.3 and 16t when I blew the motor this past winter. I was thinking about doing an ECU upgrade for the new year. Do I need to get an ECU from a 98 t5 or can I use the one that I have, for the upgrade?
dawagner93
04-26-2015 09:16 PM
denver005
03-12-2011 09:59 PM
Duake
03-20-2009 12:34 PM
S70driver
05-15-2006 05:02 PM
alecw81
Suspension
12-22-2005 07:11 PM
Quick Reply: s70 turbo upgrade......
