service light reminder?
Old 01-02-2005, 11:46 AM
pitar's Avatar
Default service light reminder?
I have a '99 S70 and recently my service light started coming on only for a first few minutes after I start the car, then it shuts off. I called dealership and they say it is just a reminder but in order to reset it I would have to come to them because they have the tools. Does anyone know if this can be done without going to stealership, are there any reset buttons or anyhing?
Old 01-02-2005, 12:28 PM
Default RE: service light reminder?
Have you tried doing a search on this site for instructions?
Turn the key to position 1 push and hold the trip reset button while holding turn key to position 2 and watch for the service light to flash 3 times then release the trip reset button and it should be reset.To make sure turn key off then start the car and make sure the light is off. Good luck
Old 01-02-2005, 01:02 PM
pitar's Avatar
Tried it, it flashed 6 times and it still stays on. My friend hooked it up to an obd2 and it's got pending code-p0532 "A/C Refrigerant Pressure Sensor A Circuit Low Input". Is this common?
Old 01-02-2005, 01:19 PM
Release it after the thrid flash or it will not reset.Clear the a/c code and see if it comes back.It could be a couple of diffrent things.But the fault might not be present at this time.So clear the code and see what happens.
Old 01-02-2005, 07:43 PM
pitar's Avatar
I managed to catch it betwen 3rd and 4th flash so it's gonne... for now anyways..Thanks!
Old 01-02-2005, 09:11 PM
No problem any time
Old 01-10-2005, 10:06 AM
i have a 2000 s-70 glt-se and i just wanted to say thanks because i have the same problem. thanks for yalls help.
Old 01-10-2005, 11:59 AM
Your welcome!
Old 01-11-2005, 08:06 PM
The service manager told my girlfreind how to do this, and she did'nt get the details right. So once again..Thanks
Old 01-11-2005, 09:35 PM
No problem!!
Old 01-12-2005, 04:15 PM
Still can't get it to flash three times. Our ignition assembly no longer "clicks" at different positions, so I suspect I am not getting position 1 quite right. Didn't replace the ignition assembly for 500 some odd dollars, I told my girlfreind not to hand a bunch of stuff off her key chain[:@]. I reread the above method, and I'll try it til I get it right...anyone else had ignition switch problems?
Old 01-12-2005, 04:55 PM
It should only be the electrical part of the switch that is bad.Should only take you about 20 to 30 min to replace.
Old 01-18-2005, 07:35 PM
Electrically, it works fine. Its the mechanical "clicks" that do not give you a positive feel for what position the key is in. Use to have a positive stop at the three different positions.
Old 01-18-2005, 08:08 PM
I understand that the feeling you are talking about it is built into the electrical part of the switch.
Old 01-26-2005, 02:28 AM
Will this work for the 1998 S70 as well?
Old 01-26-2005, 09:41 AM
No it will not work for the 98 S70 they need a service light reset tool to clear the light.
  #17
Old 01-26-2005, 12:27 PM
Any idea where to get a Service Light Reset tool and/or the cost?
  #18
Old 01-26-2005, 02:06 PM
http://www.ipdusa.com/ProductsCat.as...564&RootID=629
They are pretty expensive but this link will take you to the tool.
  #19
Old 01-27-2005, 12:52 PM
I did a search online for a Service Light Reset Tool for the 1998 Volvo S70 and found the 69007 - EXPERT QUALITY SERVIC INDICATOR TOOL - VOLVO from a Draper Tools (a UK manufacturer). This web site has the info and a link to the manual: http://www.drapertools.com/draper/Te...MainScreen.asp Do a search for Volvo and it will take you to the Reset Tool.
Do you think that this would work? There are several UK companies that are selling this tool. With the current conversion rate, it is approx $60 plus shipping. I contacted several companies to get a shipping quote.
  #20
Old 01-27-2005, 12:58 PM
Yes that will work and is for a very good price.I would buy it and then if you ever sell your car then you can sell the tool and make some of your money back.
Quick Reply: service light reminder?
