slight vibration
Something that would be worth a try is replacing motor mounts.
Philosophically, I think a full engine overhaul with additional balancing would help vibration a little. Engine vibration is necessary because the crank is being accelerated intermittently by explosions, and the block is also being pushed the opposite way by the same events. Vibration worsening caused by normal wear and tear would fall into two categories in my opinion: 1 is differences in leak down of the different cylinders. 2 is clearances that are larger than they should be. An overhaul should improve both of those.
valiant67
03-04-2008 03:27 AM
