Spare tire
So anyway, what matters about tires is the outer diameter of the tread, not the rim. If your car is front wheel drive, then the sizes of the two rear tires can be different and it would mechanically have no effect at all. Handling would be affected, and in fact it's affected with the correct size spare. Braking, play close attention and decide yourself it you think it's okay. If they are very different, the ABS will see different speeds and that might cause it to turn a light on or not work exactly right.
HummerGuy
10-10-2008 08:02 AM
