Sputter and stall when cold sometimes
Old 11-25-2006, 12:27 PM
SSGTi's Avatar
Default Sputter and stall when cold sometimes
The car is an 98 s70 t5 sometimes when its cold it will spit and sputter and sometimes stall. it runs perfectly fine when the car is warm we know the car needs a thermostat, and we just gave it a full tune up plugs cap rotor wires and the dealership put an o2 sensor 2 months ago. we hooked are obd2 reader up to it and it says random miss fire. thats why we gave it the tune up but that didnt help. any suggestions would be great. I also read alot about checking the hoses which i will do today since its such a good day. thanks alot
Alex
Old 11-26-2006, 12:17 AM
Default RE: Sputter and stall when cold sometimes
If you can check fuel rest pressure.
Old 11-27-2006, 11:34 PM
AaronD81's Avatar
Also clean the IAC
Old 11-29-2006, 03:13 PM
SSGTi's Avatar
after we changed the thermostat it hasnt done it again. so i guess it was the thermo stat making it run to cold by staying open...
Thanks though guys
Old 11-25-2014, 07:28 AM
consultrichard1's Avatar
Default S70 power loss / sputter
I read the forum replies and changed my fuel pump relay (under bonnet with relays). The car is now back to it's old self- so try that. The car would loose power on the freeway intermittently. It would start to drop rev in a line at the lights. When like this it wouldn't drive up hills or on the freeway. I gotten a relay $35 RockAuto (half price of high street)
jeffs80s
11-06-2013 09:26 PM
dman777
04-05-2011 12:38 AM
sk565
09-22-2010 06:47 PM
jwandhistools
08-11-2009 09:43 AM
JIMMY
10-13-2006 11:47 PM
Quick Reply: Sputter and stall when cold sometimes
