Upper Torque Mount
Upper Torque Mount
I just replaced my upper torque mount today. It was pretty simple in my 2003 s60 T4. However, I still have alot of play in the Strut bar mount bracket bushings...sometimes called upper torque rod brackets. I am having trouble finding the brackets/bushings to purchase and replace. Anyone know where I can purchase a set of these?
I purchased a rubber vs. urethane because I read too many bad reviews referring to excessive vibration at idle due to them being denser material and not absorbing enough of the vibrations.
I would be interested to know what you choose.
A certain amount of play is by design to allow the engine to vibrate without restraint. You do not want that rod to be held hard to the strut towers. I doubt that those bushings need replacement.
Upper Torque Mount
Thanks, James. I will leave it as is. Should all motor mounts be equally as loose?
Mounts will not last forever, but for how long I can't say. I think Volvo uses soft mountings for the 5-cyl engine because that engine has significant vibrations and oscillations due to inherent lack of dynamic balance and the design choice by Volvo of not incorporating balance shafts into the block. The Volvo diesels use vacuum mounts which are soft at idle and stiffen as the rpms increase. The Volvo petrol engines don't use vacuum mounts but at least some years use liquid filled (silicone oil I think) main support mounts which must have a shorter life than solid rubber or elastomer.
See http://en.wikipedia.org/wiki/Balance_shaft.
I am not disagreeing with that decision--that may be entirely reasonable for a 5-cyl engine of 2.4 L displacement, but GM in their Atlas series of 5-cyl engines (much larger than 2.4L) do use balance shafts.
Inline 6-cyl engines have inherently good balance, but inline 4-cyl and 5-cyl, and even V6s and V8s do not. Traditionally 4-cyl engines of displacement greater than 2.0 L are fitted with balance shafts. In the inline 4-cyl the balance shafts are parallel, twin counter rotating at twice the rotation rate of the crankshaft. This internally cancels out the inherent out of balance of the crank and pistons. The vibrations of the inline 5-cyl may not be as easily and as completely rectified by balance shafts as the inline 4-cyl.
