01 s80 t6 upgrade
with the t6 fwd you should have more than enough power.... enough to get you in trouble and burn up plenty of tires.... I would do a tune up... check the turbos and especially the waist gates and do all maintenance that you can you will likely find many factors leading to power loss especially on these cars
Actually on the turbos you can get a rebuild kit or any parts you need from xsboost turbochargers.com they are well priced and one of the best places I've done business with for turbo issues... rebuilding those turbos will run around 140 bucks.... replacement will run you over 2 grand.... Its not hard to rebuild them yourself either.... from my experience the clicking or a ringing is the compressor wheel hitting the housing.... inspect and be ready to replace the wheel if its banged up... mine were not..... when pulling the turbos mind the oil lines and buy all the new seals... these turbos also use a specific copper washer for the turbo cooling... aka coolant lines running through the turbos... now as to how to pull the turbo.... you can pull it out the top but it is a pain.... you may be best off dropping the cats and the passenger side cv half shaft to gain access and also pulling the entire exhaust manifold may be easyer than what I did in just pulling the center and compressor side.... you will probably want help.... btw you will have a coolant mess so also be ready with a drain pan behind by the turbos.... do not screw arround with old gaskets.... I cant say it enough.... check your waistgates while you are down there and make sure they are still conected to the exhaust portion... you will want to replace the pins and all the crumpling lines.... once its back together use an air compressor to pressurize the intake to test for leaks.... thats a biggie in power loss.... check and clean your etm map maf and temp sensors along with the boost pressure actuator.... k&n cone air filter is nice to get some turbo noise but you will need to fabricate a bracket.... as I have been unable to locate a aftermarket system.... If a coil is bad you will know because it will misfire and code to that specific cylinder... but I would consider injectors because those can turn into squirt guns instead of an atomizer.... be ready to replace those o rings too... also if you have not already replace your pcv system water pump timing belt thermostat cheap L connection that will break and of course all of the other timing belt related components and serp belt.... change your trans fluid and filter... new plugs and any and all engine mounts you come across because those go constaintly too... expect the 4 o2 sensors and the cats to go in the future especially if the turbos blow too much oil by after that thats everything Ive run across that will be a problem under the hood
thats not to bad i got do pvc and mounts thinking go with ipd strut mount solid and poly bushing for uper engine mount.
I under stand ill get more feed back but thats fine also all belts and what not are new and my miss is random some times car will run good then at red light rpm will just drop to like 500 then back to the 700s again? was told it maybe ummm brain fart but the etm i think need be cleaned
also do yourself a big favor do a once over on all suspension components... especially if anything is clunking... also pull off the rear discs to take a look at the ebrake... if it looks iffy replace it... mine randomly caught and sheered off the cable and a piece of the hub... in my church parking lot of all places
Im looking to pick up the icarsoft906i volvo saab scanner... Ive been told its the best for the price... let me know what your srs light code comes up as... and Im at 142k with 5 of the original coils... ive been going through advanced auto parts with the carquest coils and doing them as they go.. the carquest ones have a lifetime warranty and they are about the same price as online plus I have instaint access....
my one set off by new battery put in so think its just how it was put in bugged it out "Volvo makes some $$ reset it to" needless to say nothing bad.
was looking at Vdiag Dice Vida Volvo Vida Dice Diagnostic Tool 2014D Newest Version | eBay plugs in to laptop and change all kinda stuff able look at 02 and all that good stuff
spankey
03-28-2016 09:10 PM
Capo Cam
01-29-2008 04:41 PM
S70driver
05-15-2006 05:02 PM
