At my wits end...2004 Pulls hard when braking
Old 03-29-2011, 08:02 PM
smtm's Avatar
Default At my wits end...2004 Pulls hard when braking
My wifes 2004 S80 is driving me crazy..
About three week ago my wife told me that her car was pulling to the right when she applied the brake.
Thinking the caliper was sticking, I replaced the caliper.
Now the car is pulling to the left.
Replaced the left caliper.
Still pulling to the left.
Replaced both rotors and rotated tires front to back
Still pulling
Called FCP and they sent me another new right caliper....no change.
Just got done replacing the brakes lines...still pullls to the left
Any ideas?
Around 10k miles ago I replaced the following front end parts.
-Struts
-Strut bearings
-Lower control arms (bushings and ball joints)
-Sway bar link
-Front end alignment
Old 03-29-2011, 08:08 PM
jlewisinsyr's Avatar
Have you tried bleeding the passenger side rear brake caliper after your done?
Old 03-29-2011, 08:35 PM
smtm's Avatar
Yes.
Three times
Old 03-30-2011, 07:42 PM
Are the lower control arm bushings broke?
Old 03-31-2011, 03:57 AM
smtm's Avatar
No. I replaced the lower control arm along with the bushings and ball joint less than 10k miles ago.
Old 04-01-2011, 03:31 PM
shailey's Avatar
Default Pulling Brakes
The last time that I replaced al lof the parts that you've changed and still had a problem I found that one of the brake hoses was bad. Always change them in pairs just like calipers. You might want to invest in a pressure bleeder as well. Good luck
Old 07-27-2011, 03:15 PM
chef's Avatar
Hi there...been having the exact same issue as you, but pulling to the right...quite scary at highway speeds. In the end, it was one of the left side lower control arm bushing (one that attaches to the underbody)...the bushing was almost gone and the CA was almost resting on the frame! anyways i changed both lower control arms and the problem is gone...now i may have other issues to deal with..hahah g'luck!
fabs
Old 07-27-2011, 11:30 PM
tahafisaka6's Avatar
have you checked the struts and strut mounts?
Old 07-28-2011, 04:13 PM
75ohm's Avatar
I'm in the brake line camp...
WACKERJR
2001-2013 model year XC70
12-04-2013 08:39 AM
PAVolvo850
08-17-2013 05:19 PM
eeeewidner
1998-2000 model year V70
05-20-2013 04:42 PM
FASTER
09-22-2011 11:56 AM
jerryman
05-23-2006 01:19 AM
Quick Reply: At my wits end...2004 Pulls hard when braking
