1999 s80 will not shift into gear
Old 09-21-2009, 03:14 PM
pflinker's Avatar
Default 1999 s80 will not shift into gear
My S80 suddenly would not shift into gear yesterday. The mechanical and electronic releases are working fine. When taken out of park I can pull the handle back but nothing happens, it stays in park. I took the cover off the shifter and can see the cable moving but there is a fair amount of resistance and it gets tighter the farther back I pull but there is no indication that anything is engaging. The light continues to stay on P and I cannot move the car.
Any help is greatly appreciated.
Old 09-21-2009, 08:01 PM
Maybe the shifter cable is bad under the hood.
Old 10-12-2009, 09:28 AM
4g63's Avatar
My wifes car did the same thing when she parked on a hill. I had to "shift" the weight of the car back and forth, then the shifter worked normally.
Old 07-21-2011, 01:29 PM
cbcustoms's Avatar
what was the out come ? My car is a 1999 doing the same thing ! shifts fine no go dash indicater stays on "p" ..
Old 07-25-2011, 12:23 PM
speedracersworld's Avatar
It's your shifter cable. The plastic coating on the cable housing has deteriorated and coming off so the housing gives & expands instead of moving the inner cable. You'll need to replace it.
Old 07-25-2011, 12:48 PM
S80Girl99's Avatar
Is this common in the S80's??
Old 07-26-2011, 06:37 AM
It's more of a age and the deterioration on plastic and rubber parts due to time and especially conditions in the hot area of the engine compartment. That affects all cars.
Old 07-28-2011, 07:50 PM
cbcustoms's Avatar
Fixed it last night New shifter cable and some adjustments it was like new. It took me about two hours not that hard just tedious when removing the console. and routing the new cable. thanks for the help.
Old 07-29-2011, 06:45 AM
Awesome! Glad to hear that it's fixed
elchingon2002
07-22-2014 06:09 PM
96850urbo
04-09-2009 01:33 PM
Vee
01-13-2009 06:05 PM
Quick Reply: 1999 s80 will not shift into gear
