2000 s80 Immo failure
Old 02-18-2017, 05:49 AM
lostys's Avatar
Unhappy 2000 s80 Immo failure
hi. i have a 2000 s80 t5, i had to change the key.
here s the problem :
when i lock the car with remote, after some time, for example 10 mins, the remote does not respond and unlock the car. i unlock the doors manually, with the key, get in the car, insert the key in the switch, turn it on and then :
1-the headlights are on (the headlight key is off), no dashboard and warning lihgts, the engine does not start. then i turn it off.
2-i turn the key on again, headlights are off (the headlight key is off), the dashboard lihghts and warning lights are on. the engine does not start. then i turn it off.
3-i take out the key, then insert again, turn it on, then as usual, the engine starts.
everytime it happens step by step. nothing changes.
what is the problem? what should i do ?
thanks in advance.
mrswarren619
11-09-2013 07:49 AM
jasonthaynes
12-02-2012 05:32 PM
brokevolvo
10-24-2011 10:56 AM
kosmoscanyon
12-16-2008 12:39 PM
Quick Reply: 2000 s80 Immo failure
