Cig Lighter Blows Everytime
Old Feb 8, 2008 | 01:22 PM
Capo Cam's Avatar
Default Cig Lighter Blows Everytime
Everytime I use the cigarette lighter for my cellphone charger or a cigarette lighter the fuse blows within 10-15 minutes? Any suggestions? I tried using one size larger fuse (not sure if that was a good idea or not) but it still blows out.
Thanks,
Cameron
Old Feb 9, 2008 | 09:58 AM
Default RE: Cig Lighter Blows Everytime
Maybe the charger is bad?
Volvo's are very touchy about cell phone chargers.
Old Feb 9, 2008 | 12:25 PM
Capo Cam's Avatar
It seems to work in my other two vehicles without any problems? This happens when I use either of two different chargers and also just when wusing a standard cigarette lighter too?
Old Feb 9, 2008 | 12:39 PM
Did the lighter come with the car?
Volvo is very picky about the chargers like I said I see atleast 1 to 2 a week that a charger will blow the fuse but I replace the fuse and test with other things abd everything works fine.
Old Feb 9, 2008 | 02:13 PM
Capo Cam's Avatar
ORIGINAL: tech
No sir it did not. The previous owner was a non-smoker. So possibly that is the cause?
Old Feb 9, 2008 | 05:34 PM
It might be I think the Volvo ones are pretty unique.
Old Feb 18, 2008 | 12:48 PM
Worthitall's Avatar
[align=left]I just bought an '05 S60. Neither charger was working, so I asked the service department about it. I was told that the Volvo 12V chargers are a "European size" that doesn't work reliably with American-size chargers. They suggested having the charger plugged in before the car is started to avoid blowing the fuse. That seems really inconvenient to me, because I use the charger for my phone when it's dying. I don't want to have to pull over, turn the car off, jack in the charger, etc. just to continue a call. I am hoping there is some adjustment or adapter for a phone charger that will solve this issue.
[/align]
Old Feb 19, 2008 | 11:15 AM
Capo Cam's Avatar
I have the stock size fuse back in there but now it doesn't work at all? Doesn't blow the fuse or anything?
Old Feb 19, 2008 | 06:23 PM
HMMM maybe you have codes in the climate module and it is shutting it off.
The lighter is also powered/ running through the climate module.
Old Feb 20, 2008 | 10:42 PM
Capo Cam's Avatar
Dunno what happened, but now it has been working fine the last day?
Newport_j
Feb 18, 2014 08:17 PM
slowtype
Feb 11, 2012 04:35 PM
ianparsons
Nov 10, 2008 12:14 PM
Stangfreak21
Oct 20, 2008 01:33 PM
kartman01
Jul 3, 2008 09:16 PM
