Go Back   Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo S80
Sign in using an external account
Register Forgot Password?
Search
Welcome to Volvo Forums!
Welcome to Volvo Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Volvo Forums today!
LinkBack Thread Tools Search this Thread
Old 02-08-2008, 12:52 PM
Default 2001 S80 Timing Belt replacement DIY?
My school teacher daughter has this car and ask me to replace the timing belt. Like dads everywhere I said sure order the parts and a book. Wellshe has the parts but the book (DVD) she ordered is junk. We can't find a book for this year. Is it available at a dealer. Is this job possible for a DIY job. I've done several Toyotas in the past. She does not have the 800 the dealer wants to do this work. We have belt, water pump and tensioner do we need an idler also.
Thanks
Sherm
__________________
Sherm
Old 02-09-2008, 09:54 AM
Default RE: 2001 S80 Timing Belt replacement DIY?
Yes do the idler as well.
It is pretty straight foward.
Before removing the belt make a mark from the pully to the cam cover. Sometimes the VVT pulley will move some. Then when installing the new belt make sure the marks are lined up and you will be fine.
The crank mark is hard to see unless you remove the lower crank pulley. There is an outer pulley that holds the serp. belt in remove than then the crank pulley and you should see it pretty good.
Also there is 2 types of marks on them. 1. There is a slot cut into the 2 teeth and you would line up the mark on the engine beteen the 2 marks. 2.One line is cut at the bottom of the groove for the tooth and you line that up.
__________________
1987 Ford mustang LX Coupe 5.0
1995 Yellow T5-RM running
1996 850 turbo
1994 N/A 5-speed wagon Purple (daughters)
Old 02-09-2008, 08:05 PM
get the car in a well lighted warm place, also pull the pass side tire , take your time, take your time, check and double check, take your time, a good helper is a must also, this job can be done by a D.I.Y but just remember, take your time. good luck to you.
__________________
rick caldwell
Old 02-10-2008, 03:08 AM
Capo Cam's Avatar
I am also going to be diving head first into this job in two weeks. My '99 I bought used and has pretty high miles so I figure "better safe than sorry". Ah, a heated garage, a couple friends, some beer and bloody knuckles...outta be fun I am going to buy the kit which includes: timing belt, timing belt tensioner, and timing belt idler. What else will I need? Gaskets, loctite, 1 less beer...lol.. I haven't looked to see what all I will be needing to take off of the car yet to get to the timing belt. Water pump, etc.
Here is the kit I was looking at:
http://cgi.ebay.com/ebaymotors/ws/eB....cWAT.m240.lVI
Old 02-10-2008, 03:28 AM
2002 Volvo S80
It looks like a good kit, but from what im seeing it would be cheaper to rder the actual individual parts from http://www.eeuroparts.com/searchresu...3&cat=1014
Its also a good site so its no problems regarding trust.. You also get free shipping here. The link I sent you is also for a continental belt, so save some money and leave ebay out of it this time
__________________
2002 Volvo S80 2.9
1997 Honda Accord EX 2.0 F20B2
http://i509.photobucket.com/albums/s...ility004-1.jpg
Old 02-10-2008, 08:08 AM
go to the volvo parts club, buddy is a good guy and the parts are cheaper in cost that that e-bay deal, plus free shipping
__________________
rick caldwell
Old 02-10-2008, 08:12 AM
yes e-europarts, another great place to buy from, buddy at volvo parts club and e-europarts, my two choices for my volvo.
__________________
rick caldwell
Old 02-10-2008, 12:06 PM
Capo Cam's Avatar
Thanks for the info guys. I will check those sites out!
Old 02-19-2008, 04:03 PM
Thanks for the replies. I have one very important question. That is, what does the timing mark look like on the crank seal carrier plate. Is it the cast in flange with the little dot on the end or what. I am about ready to pull all the pullies off the crank to make sure I am doing this right. My son in law wanted to help so he just pried the belt off without asking so I have to start from scratch. I found the little notched mark on one crank pully tooth so I think I'll be ok on that side of the set. I'm ok on the cams I have found marks on both sprockets and have aligned them with the notches in the top cover. I sure would like to see a picture of the marks for the crankshaft. Today I am working in the driveway in the rain. I didn't want to get my boat wet by putting it outside.
Thanks
Sherm
__________________
Sherm
Old 02-19-2008, 06:37 PM
Click the image to open in full size.
Thats a 850 one but very similiar trying to find one more from the top.
I thought I had a better one but I can't find it.
__________________
1996 850 turbo
Tags
2001, 2002, 29, belt, book, chain, change, installing, long, replacement, s60, s80, time, timing, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
Secure Backup
