2002 S80 T6 oil leak - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 03-13-2008, 09:53 AM
Default 2002 S80 T6 oil leak
My S80 has 65K miles. I have on oil leak somewhere because my oil level is constantly low and I have to keep adding oil.
I obviously have to get it checked out but the two symptons I have noticed are oil leaking around the oil filler cap and smoke coming out of the dipstick tube after the car has been idling for a while. The oil on the dipstick seems normal though (i.e. no sludge or anything like that).
Is this most likely a clogged breather valve/breather box? I have been consistent with my oil changes (every 3K to 4K miles) and my mechanic uses Castrol GTX, so I would be a little curious as to why the breather valve would be clogged at 65K.
Could the smoke from the dipstick and leaks around the oil cap be indicative of any other type of problem?
Thanks in advance for your help.
Old 03-13-2008, 08:46 PM
Default RE: 2002 S80 T6 oil leak
Sounds like something in the vent system is clogged.
There is a hose or fitting on the intake that will get clogged and act like this.
Thread Thread Starter Forum Replies Last Post
2002 S60 Engine Oil Leak Front Passenger Side joshuapfitzpatrick Volvo S60 & V60 1 06-25-2012 11:57 AM
2002 S80 T6 Massive Oil Leak! TigerGoosebark Volvo S80 12 03-09-2012 09:41 AM
2002 S80 T6 PCV Service - Still have oil leak skooter66 Volvo S80 9 10-28-2011 09:08 AM
2002 s80 2.4 auto petrol. oil leak bobloftus Volvo S80 1 06-26-2010 03:06 PM
2002 S40 water in oil, oil cooler leak rare illfrom Volvo S40 0 03-07-2010 10:15 AM
Tags
0il, 2002, blowing, breather, cap, dipstick, filler, leak, leaking, leaks, oil, s80, s80t6, t6, valves, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
