AC low pressure side
Old 08-14-2012, 04:19 PM
vrhs2011's Avatar
Default AC low pressure side
So, I need to recharge my AC, its starting to get cool; and I really don't feel like paying $268 at the dealer. Anyway, after doing some research, It seems like the low pressure port is under/near the coolant and power-steering tanks. that cap is marked by a '6nm MAX'. Is this correct? Thanks.
1999 S80 T6
Old 08-14-2012, 05:04 PM
Yes just did mine.
Old 08-14-2012, 05:50 PM
akabond's Avatar
wait..so what did you do . And what you mean by recharge the A/C
Old 08-14-2012, 10:21 PM
vrhs2011's Avatar
@ Quietlymknnoise - How did you get the cap off??., it seems kinda tight in space wise
@ akabond- Well top it off with R134-a.
Well I couldn't do it today, too hot, and the engine needs too cool down.... Which can take awhile.
Old 08-15-2012, 04:59 PM
I used a 19mm socket to loosen cap then attached a PRO AC recharge hose to it. I set air temp gauge, read pressure, then pulled trigger and away she charged up. Stopped at 37 psi with air temp of 85 degrees which a little low for air temp.
bydand
2001-2013 model year XC70
46
10-23-2018 11:11 PM
brettboze
03-26-2012 06:25 PM
pturner
06-25-2010 11:29 AM
STREETFIGHTER50
03-12-2009 07:29 PM
elderzap
11-07-2007 04:58 PM
Quick Reply: AC low pressure side
