2006 S80 Cranks, No Start
Old 02-09-2017, 10:44 PM
Kevin Paul's Avatar
Default 2006 S80 Cranks, No Start
After having the PCV system replaced, the 2006 Volvo S80 2.5t Turbo with AWD will not start. The starter cranks, the timing belt spins, the water pump and accessory belt spins but the engine does not start. There is pressure in the fuel bar, check with the schrader valve. There is no spark in at the plugs. I Ann it sure if fuel
is coming out of the injectors. I have checked all of the connections to ETC, MAF, fuel
injectors, thermostat, TPC valve, cam sensor and crank sensor. Triple checked all
vacuum hoses.
batter has been charged to 100%
tried resetting ECM with disconnected battery
replaced plugs with Volvo plugs
replaced cam sensor
Any Help would be appreciated
Old 02-10-2017, 06:54 PM
Kevin Paul's Avatar
Default OTC compression test -150
Today I hooked up the OTC Conpression Kit to each of the 5 cylinders, after disconnecting the fuel injectors and coil packs to the plugs. When I pulled each plug they were wet and smelled like gasoline.
The Compression on each was 150psi..
nightmarevolvo
02-04-2023 06:20 PM
Luvmateo
11-30-2014 08:22 PM
rainman14624
09-20-2010 09:22 PM
mracr
02-14-2007 12:53 PM
Ahhsk
01-25-2006 12:15 AM
Quick Reply: 2006 S80 Cranks, No Start
