3.2L water pump change
Old 04-15-2015, 06:40 PM
331stroker's Avatar
Default 3.2L water pump change
has anyone replaced a water pump on 2007 or so S80 ?? looks like a huge project, having to remove P/S pump etc. please any advice would be greatly appreciated. Thank you.
Old 04-16-2015, 07:03 AM
ES6T's Avatar
I've done a few. They aren't too bad. As you mentioned, the power steering pump needs to be removed.
Old 04-16-2015, 05:06 PM
331stroker's Avatar
thanks, I assume it slides off a shared shaft of the water pump pulley? is it necessary to remove hi/ lo pressure lines? to remove completly or just leave floating?? thanks again for the help. Roger
Old 04-16-2015, 05:37 PM
ES6T's Avatar
If you look closely, you'll see two T25 screws that holds the power steering pulley to the water pump drive.
I've always removed both lines to make it easier.
Old 04-16-2015, 05:40 PM
331stroker's Avatar
Thanks a million!!!
Old 04-17-2015, 09:13 PM
331stroker's Avatar
removed P/S pump w/ pulley and water pump today, went smooth. water pump was seized and shredded the coupling. Will order parts soon. Thanks for advice again.
Old 04-30-2015, 05:11 PM
331stroker's Avatar
any tips on replacing serpentine belt? a/c compressor has to be moved to get belt around tension pulley? thanks
Old 05-01-2015, 09:01 PM
damien360's Avatar
Yeah the a/c compressor have to be removed along with the power steering pump pulley.
Old 05-01-2015, 09:14 PM
331stroker's Avatar
Thanks new water pump in and water pump drive. old belt back on . taking compressor an d bracketry out too big of a project.
majorcode
11-04-2013 06:41 PM
volvoQ's
11-13-2010 02:47 PM
joggieroets
08-26-2010 06:19 PM
kingmf
02-17-2010 10:07 PM
95volvo850
09-16-2009 09:30 AM
Quick Reply: 3.2L water pump change
