ABS fault
Old 04-25-2017, 02:31 AM
hundolfini's Avatar
Default ABS fault
Hello, i have a problem with my ABS, and i dont know if its failing, or maybe has some loose connection, or relay? Cars is Volvo S80 2007m D5 136kw
The sympthoms:
Three months ago once abs fault popped out, and i cannot reset it. I thought i will need to repair it. but in the morning fault was gone, and for three months i was dirving without abs faults, but this weed this started again, sometimes abs fault shows on, sometimes after restarting engine is OK, but sometimes it's on for a long time. So i dont know if the pump motor is failing, or i have a bad connection, or bad relay. The fault code is - BCM-C00201C (ABS pump motor control. General electrical failtures. Circuit voltage out of range)
Does anyone had similar problem or maybe knows what is failing in my car?
Thank you!
v1lcins
05-20-2022 10:53 AM
denver005
06-11-2009 08:02 AM
jeffwi850
08-16-2007 08:29 PM
darren.m
09-06-2005 08:33 PM
darren.m
09-01-2005 11:51 AM
Quick Reply: ABS fault
