AM Radio useless due to static and poor reception
Old 06-25-2014, 06:37 PM
evlwhtguy's Avatar
Default AM Radio useless due to static and poor reception
I just purchased a 2006 S80 NO AM!!! I tried the brass strip fix....no joy!!! I travel and I will die a slow death if I have to listen to NPR all day [National Proletariat Radio] I gotta have AM talk! Any suggestions?
Old 06-25-2014, 09:54 PM
damien360's Avatar
Sounds like an IAM
difflock54's Avatar
Whats it like on FM bands?
Old 06-26-2014, 07:00 AM
evlwhtguy's Avatar
Works like a champ. Interestingly, when I disconnected the antenna amplifier [little green box] in the passenger rear quarter panel by the bumper, the FM continued to work just fine.
Old 06-26-2014, 11:51 AM
damien360's Avatar
The IAM ( CD player) sounds like it had failed
Old 06-27-2014, 06:29 AM
evlwhtguy's Avatar
I saw that mentioned earlier and didn't know what it meant. How do I check that? Do I put a CD in it and see if it works? [I am such an old dude that I don't carry CD s around with me]
Old 06-30-2014, 09:36 AM
evlwhtguy's Avatar
Default The CD player works
I found a CD and tried the CD player, it works fine. I also went to pull-a-part and tried a new antenna booster [the little green box that you put the brass strip on the connector of] and that made no difference. Quite frankly I really cant see what that little brass strip actually does. The purported reason for using it is to help with grounding, but the end of it is taped to the plastic side of the little green antenna booster box, how the heck is that supposed to make any difference???
Old 06-30-2014, 10:12 AM
evlwhtguy's Avatar
Old 06-30-2014, 12:32 PM
ES6T's Avatar
As was mentioned already, you need to replace the CD player.
Old 07-01-2014, 06:20 AM
evlwhtguy's Avatar
You mean replace the whole radio/cd unit? They are one unit.
Old 07-01-2014, 09:25 AM
ES6T's Avatar
Yep. It's called the IAM. There is a bulletin about it for this exact issue.
Old 07-02-2014, 06:29 AM
evlwhtguy's Avatar
Would that be 3bulletin....39-0018 and 39-0025
those are about the brass strip, which I have already tried. If there is another bulletin, what number is it?
Also, If I got a radio from a junker, would it work without the dealer PROGRAMMING IT?
Old 08-01-2014, 06:38 PM
evlwhtguy's Avatar
Default Window antenna
I found the window antenna and moved the brass strip to the window antenna coax cable/booster connection, but it made no improvement.
kawish1659
06-06-2013 10:41 AM
pphilps
07-27-2011 03:53 PM
arlen
12-16-2008 01:29 PM
JasonR
09-25-2007 07:52 PM
Quick Reply: AM Radio useless due to static and poor reception
