Beelding brake oil VS Power Flush
Old 10-24-2014, 10:02 AM
Sherry007's Avatar
Default Beelding brake oil VS Power Flush
I finally decided not to bleed brake oil from brake caliper, kind a careful and messy job for me...bcz have to do by my self.
What if I power flush the brake oil using machine or power bleeder. Hope no harm by using. Kindly advise.
Old 10-24-2014, 10:18 AM
ES6T's Avatar
No harm at all. Just goes quicker. We use them all the time at the dealer.
Old 10-25-2014, 03:06 PM
Sherry007's Avatar
Since I did not find power flush machine around me, I finally did it my self by bleed oil from caliper. The procedure gone smooth. But I suspect two issue but not sure they are serious enough.
1. While taking oil out from caliper I did press and depress the brake few times to get the oil out...otherwise it was not coming (In between I did try to put the handbrake down and put the gear in N so that I might see good flow of oil.
2. Brake is working perfect while drive and no warning sign on dash, but the problem I see that my brake lights still ON while driving, so when I checked I saw my brake pad has a play now or may be lose.
Rest All fine. Kindly advise.
patrm
2001-2013 model year V70
23
03-05-2014 08:43 PM
shop2
11-01-2011 08:56 AM
nicolaselias
03-24-2011 08:48 PM
tjmm1335
04-09-2009 09:07 PM
Glenn B
02-19-2008 04:57 PM
Quick Reply: Beelding brake oil VS Power Flush
