2009 Volvo S80 fuel pump Location
Old Jul 24, 2021 | 08:38 PM
pplayground's Avatar
Question 2009 Volvo S80 fuel pump Location
Hi, I have a 2009 Volvo S80 T6 AWD 3.2L, i need to replace the Fuel pump I took out the backseats but can't seem to locate it
any help will be appreciated
Old Jul 25, 2021 | 09:34 AM
After you take the gas tank out - you can get to it. Why do you "need" to replace the fuel pump?
Old Jul 25, 2021 | 10:11 AM
ES6T's Avatar
You need to drop the tank.
Old Jul 25, 2021 | 12:01 PM
Default No
I was driving down the highway and the car died and there is no fuel coming to the motor or the rail
Old Jul 25, 2021 | 12:27 PM
There's a lot of stuff that makes that fuel pump run - fuse 22 and relay k8 on the CEM, a fuel pump control unit (PEM) 4/83 in the diagram and the fuel pump is 6/33. The fuel pump only runs at the speed needed - the fuel pressure sensor on the fuel rail is the signal for that. Rarely do fuel pressure sensors cause the car to die - but it's possible. A good scan tool or VIDA would be the best first step in your diagnosis.
robertMTL
2001-2013 model year XC70
Mar 2, 2021 02:40 PM
acRainiar
Sep 2, 2019 03:32 PM
Walter M Hanson
Feb 23, 2019 08:15 PM
Falcon690
Dec 11, 2016 08:34 AM
cganesh75
Jun 22, 2015 05:31 AM
